Hi, im trying to do a Alert Button in the Tags, is it posible to do it ? Because the PANS libs are not available to change.
Im using the dwm-simple.c Code as main code to modify.
Thanks !
Thanks !
Hi Franco,
What do you exactly mean by alert button ? Send a customized UWB signal when the button is pressed on the tag ?
We have just released a new version of the firmware allowing to send data, and with a bit of customization in the user app, it should be possible to perform what you want to achieve. Please have a look at the official release thread there:
https://forum.qorvo.com/t/dwm1001-pans-release-2/4347/2
There is a bit of work to get start (you need to add a gateway in the network in order to send uplink data from the data as well as receiving downlink data.)
Let me know how it goes,
