I am trying to create a network using DWM1001 modules through a custom made application. I have successfully configured the module as anchor or a tag and I am also able to change it’s configuration. But I’m facing issues in changing name of the modules and network.
Can anyone tell me which parameter I need to change to change the name of module and network?
Thanks,
Hanish
Hey Hanish,
Is it a custom BLE application ?
Hi Yves,
Yes, it is custom BLE application and I am able to configure a module as an anchor or a tag. Also, I am able to change other features like enabling or disabling UWB and LED but I am not able to change name of module and network.
Thanks,
Hanish
Hi Hanish,
have you tried to read how it is done in the DRTLS Manager source code? The code is available from the download. It works with the DRTLS Manager so there must be some issue in your code.
Another option is to change the label and network via shell using the commands
dwm> nls
dwm> nis
Cheers,
TDK
