Hi Qorvo teams,
I am using a cascade LNAs TQP3M9009 with single power supply +5Vdc.
And I met a oscillation problem now.
I measured the cascading output, there is a harmonic around 350MHz and 700MHz.
Below attached the schematic and PCB layout.
I did use a solid ground plane beneath the LNAs.
I use a spectrum analyzer to the 2nd-stage output, there is a oscillation at 350MHz and 700MHz.
I need HELP about this issue.
Thank you so much.
SK.
