Hi all,
See this video I made here showing this problem: https://youtu.be/50u2MJST5O4
I can read the distance fine between each responder in isolation, but trying to read in multi mode, I am getting RX_TIMEOUT errors…
I used RESPF -CHAN=5 -ADDR=2(3) -PADDR=0
for the 2 responders, and I used INITF -CHAN=5 -ADDR=0 -MULTI -PADDR=[2,3]
for the initiator.
As you can see in the video, I can read the distance to each responder individually, but not all at once.
The firmware should allow up to 8 responders by default. What could I be doing wrong?
Thank you!
