Are there any tips and tricks I’m not aware of for using flip flops, especially D_type in my case? I can’t get any meaningful output…I’m attempting to create two 50% square waves from a clock source. I’ve also tried different combinations of bias on Preset and Clear inputs, and various RC initialization type arrangements on these pins to no avail. Any help appreciated. I have a feeling I’m doing something obviously wrong
your clr = 1 all the time and pre = 1 too ,just get a truth table
It seems that, unlike the 74HC74, the “PRE” and “CLR” pins are active high.
Therefore, you need to set these pins to low
Thank you all for the replies. I actually made the mistake of having a node named '“a” in a different part of the circuit. Should have used Q. Sorry to waste your time, but I will say that I have used other simulators where case sensitivity wasn’t an issue. Anyways, I’m not going to try and save face too much on this one. Thanks again
