It is really ironic that Qorvo provides a software package that does not compile out of the box.
Note: I downloaded 17.0.2 nrf sdk as per readme.md found in the sdk folder.
First issue, I faced was that __vprintf does not exist. I solved it removing the SEGGER_RTT_Syscalls_SES.c file. Now the program compiles while all the examples are disabled.
Now, I want to read the device id to ensure that device is working. Therefore, I go to example_selection.h and uncomment the 1st example which is “TEST_READING_DEV_ID” and then I try to build it again. This time again it does not compile with the following errors:
