How to burn the install code, MAC address, and other factory data?
Modify factory data in factoryblcok.xml file
1. Windows Environment
Can use qpg6200-iot-sdk
(1) Install Vscode and install necessary tools
- MinGW or MSYS2:provide make、bash、gcc etc tools(recommend MSYS2)
- GNU Arm Embedded Toolchain:used in ARM build
- Python: need
- make sure make put in PATH,put in command line
make --version
to check version info
(2) Config Vscode
- open SDK root dir(example:
qpg6200-iot-sdk-main
) - choose terminal MSYS2/MinGW bash(recommend MSYS2)
- choose in VSCode terminal menu “new terminal”,choose bash。
- check Makefile path
- example: Zigbee Switch Application Makefile Path:
Applications/Zigbee/Switch/Makefile.Switch_Zigbee_qpg6200
- example: Zigbee Switch FactoryBlock Makefile Path:
Libraries/Qorvo/FactoryBlock/Makefile.FactoryBlock_qpg6200_Switch
Can’t use qpg6200-iot-sdk
(1) translate makefile recipts into .bat language
(2) Open Powershell
Write Command as follow:
cd .\Desktop\6414
./buildall.bat
(3) Check hex file in work folder
2. Ubuntu Environment
Enter Command in terminal as follow:
cd qpg6200-iot-sdk
source ./Scripts/activate.sh
cd Libraries/Qorvo/FactoryBlock
make -f Makefile.FactoryBlock_qpg6200_Switch
normal issue:
(1) Python version is wrong
cd qpg6200-iot-sdk
python3 --version
##if print python3.10.x is suitable
##if print python3.11 please enter follow command
sudo update-alternatives --config python3
##select python3.10.x
(1) Check if there is arm-none-eabi-objcopy in you path :/usr/bin/arm-none-eabi-objcopy
##if you don't have, please download from apt
