I have been reading all the documentation I could find about the DWM1001 and I have purchased 5 DWM1001-Dev equipment to evaluate the product and see if its use for an indoor location project is feasible.
All the initial tests have been satisfactory, setting the environment is quick and easy, setting up a network is very simple … but we have encountered some problems as we have go into detail about how to perform the final application.
[list]
[]In many documents such as can be DWM1001 Firmware User Guide or DW1001 Firmware API Guide there are references to DWM1001 BLE API Guide or DWM1001-Bletooth-API but I have not found it anywhere.
[]In the same documents there are references to Configure DWM1001 as a Gateway to receive the position of all Tags in the system but I have not found how to do it.
[*]Also there are references of Gateway using Raspberry Pi and Publish the data using MQTT but I have neither found it.
[/list]
[color=#333333]I already have a small test network with 4 Anchor, 1 Tag and 1 Listener, using DWM1001 DEVELOPMENT BOARD and everything is working fine.[/color]
[color=#333333]The next steps will be to create a network with more TAGs to see their behavior and add options into the Listener to send the positions of all TAGs to the cloud.[/color]
I assume that MDEK1001 Development Kit is completely compatible with DWM1001 DEVELOPMENT BOARD, am I right?
