Hey everyone,
I am a beginner to UWB communications. I recently purchased a few UWB Click modules in which I hoped to be able to connect with separate Arduino’s to be able to send and receive data between them. The UWB Clicks al have a DWM1000 transceiver chip, which lead me to install and use the DW1000.h library in the Arduino IDE. Inside that library, two example files are included which I will provide below (BasicSender.ino and BasicReceiver.ino).
When I run upload files (on different computers to different Arduino boards), I get initialization for both of them and then no data that I can tell is being transmitted. I am running a spectrum analyzer configured to 6.489 GHz (the default frequency for channel 5 within the library), and not seeing any signals coming from the transceiver module/antenna.
My current pin setup for both boards is:
| Arduino | UWB Click |
| Pin 13 | SCK |
| Pin 12 | SDO |
| Pin 11 | SDI |
| Pin 10 | CS |
| Pin 9 | RST |
| Pin 2 | IRQ |
| 3.3 V | 3.3 V |
| GND | GND |
My question is what am I doing wrong that I am not able to transmit the data successfully? Let me know some other troubleshooting techniques I should try in an attempt to fix this. Thanks!
Transmitter:
* Copyright (c) 2015 by Thomas Trojer <thomas@trojer.net>
* Decawave DW1000 library for arduino.
* Licensed under the Apache License, Version 2.0 (the "License");
* you may not use this file except in compliance with the License.
* You may obtain a copy of the License at
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS,
* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
* See the License for the specific language governing permissions and
* limitations under the License.
* @file BasicSender.ino
* Use this to test simple sender/receiver functionality with two
* DW1000. Complements the "BasicReceiver" example sketch.
* @todo
* - move strings to flash (less RAM consumption)
#include <SPI.h>
#include <DW1000.h>
// connection pins
const uint8_t PIN_RST = 9; // reset pin
const uint8_t PIN_IRQ = 2; // irq pin
const uint8_t PIN_SS = SS; // spi select pin
// DEBUG packet sent status and count
boolean sent = false;
volatile boolean sentAck = false;
volatile unsigned long delaySent = 0;
int16_t sentNum = 0; // todo check int type
DW1000Time sentTime;
void setup() {
// DEBUG monitoring
Serial.begin(9600);
Serial.println(F("### DW1000-arduino-sender-test ###"));
// initialize the driver
DW1000.begin(PIN_IRQ, PIN_RST);
DW1000.select(PIN_SS);
Serial.println(F("DW1000 initialized ..."));
// general configuration
DW1000.newConfiguration();
DW1000.setDefaults();
DW1000.setDeviceAddress(5);
DW1000.setNetworkId(10);
DW1000.enableMode(DW1000.MODE_LONGDATA_RANGE_LOWPOWER);
DW1000.commitConfiguration();
Serial.println(F("Committed configuration ..."));
// DEBUG chip info and registers pretty printed
char msg[128];
DW1000.getPrintableDeviceIdentifier(msg);
Serial.print("Device ID: "); Serial.println(msg);
DW1000.getPrintableExtendedUniqueIdentifier(msg);
Serial.print("Unique ID: "); Serial.println(msg);
DW1000.getPrintableNetworkIdAndShortAddress(msg);
Serial.print("Network ID & Device Address: "); Serial.println(msg);
DW1000.getPrintableDeviceMode(msg);
Serial.print("Device mode: "); Serial.println(msg);
// attach callback for (successfully) sent messages
DW1000.attachSentHandler(handleSent);
// start a transmission
transmitter();
void handleSent() {
// status change on sent success
sentAck = true;
void transmitter() {
// transmit some data
Serial.print("Transmitting packet ... #"); Serial.println(sentNum);
DW1000.newTransmit();
String msg = "Hello DW1000, it's #"; msg += sentNum;
DW1000.setData(msg);
// delay sending the message for the given amount
DW1000Time deltaTime = DW1000Time(10, DW1000Time::MILLISECONDS);
DW1000.setDelay(deltaTime);
DW1000.startTransmit();
delaySent = millis();
void loop() {
if (!sentAck) {
return;
// continue on success confirmation
// (we are here after the given amount of send delay time has passed)
sentAck = false;
// update and print some information about the sent message
Serial.print("ARDUINO delay sent [ms] ... "); Serial.println(millis() - delaySent);
DW1000Time newSentTime;
DW1000.getTransmitTimestamp(newSentTime);
Serial.print("Processed packet ... #"); Serial.println(sentNum);
Serial.print("Sent timestamp ... "); Serial.println(newSentTime.getAsMicroSeconds());
// note: delta is just for simple demo as not correct on system time counter wrap-around
Serial.print("DW1000 delta send time [ms] ... "); Serial.println((newSentTime.getAsMicroSeconds() - sentTime.getAsMicroSeconds()) * 1.0e-3);
sentTime = newSentTime;
sentNum++;
// again, transmit some data
transmitter();
Receiver:
* @file BasicReceiver.ino
* DW1000. Complements the "BasicSender" example sketch.
* @todo
#include <SPI.h>
#include <DW1000.h>
// connection pins
volatile boolean received = false;
volatile boolean error = false;
volatile int16_t numReceived = 0; // todo check int type
String message;
void setup() {
// DEBUG monitoring
Serial.begin(9600);
Serial.println(F("### DW1000-arduino-receiver-test ###"));
DW1000.setDeviceAddress(6);
char msg[128];
// attach callback for (successfully) received messages
DW1000.attachReceivedHandler(handleReceived);
DW1000.attachReceiveFailedHandler(handleError);
DW1000.attachErrorHandler(handleError);
// start reception
receiver();
void handleReceived() {
// status change on reception success
received = true;
void handleError() {
error = true;
void receiver() {
DW1000.newReceive();
// so we don't need to restart the receiver manually
DW1000.receivePermanently(true);
DW1000.startReceive();
void loop() {
// enter on confirmation of ISR status change (successfully received)
if (received) {
numReceived++;
// get data as string
DW1000.getData(message);
Serial.print("Received message ... #"); Serial.println(numReceived);
Serial.print("Data is ... "); Serial.println(message);
Serial.print("FP power is [dBm] ... "); Serial.println(DW1000.getFirstPathPower());
Serial.print("RX power is [dBm] ... "); Serial.println(DW1000.getReceivePower());
Serial.print("Signal quality is ... "); Serial.println(DW1000.getReceiveQuality());
received = false;
if (error) {
Serial.println("Error receiving a message");
error = false;
Serial.print("Error data is ... "); Serial.println(message);
