Automatically export data to csv
Hi is there a possibility to automatically export in each run specific nets to a CSV file? In addition can I designate the time range in which the data will be exported? I though of creating a C block that does it, but a build in feature is preferable. Thank you.
I do it with a C-block, but it is possible to do it with command mode, where up to QUX -Export command, you can specify to write into CSV format.
