I recently came across this paper on AoA:
- Can Decawave comment on when this evaluation kit will be available?
- Alternatively, is it possible to do a similar setup using two EVBs clocked from the same crystal?
There is an Evaluation Kit based on PDOA - limited availability. Instead of AOA Now we call it as PDOA.
Please refer this newsletter for more details - https://www.decawave.com/wp-content/uploads/2018/11/November-2018-Decawave-Newsletter.pdf
The PDOA Node Kit is designed based on two DW1000 chips clocked from same crystal.
Thanks & Regards,
Deepa
Deepa:
I would like to use PDoA for a project that’s at the beginning of the design stage.
How do I get hold of a PDoA Eval Kit?
Josh
Hi Josh,
Please go through the docs shared as part of the PDoA Evaluation Kit
These documents defines the overview of the PDoA Kit and how to use it
These documents defines the PDoA Node, Tag and RTLS PC Application
This document explains about how to determine Phase Difference of Arrival
Thanks & Regards,
Deepa
Hello, Deepa,
I’ve recently started delving into PDoA, but I’m having trouble accessing the materials. Even though it’s been almost 5 years, I still hope to explore if you could provide access to these materials. Perhaps you could send them to my email at 942792510@qq.com.
Thank you very much, regardless of the outcome.
