I want to obtain location of tag using UART for that i was passing shell commands using tera term terminal. When i passed Double Enter in 1 second then it switched to shell command but on passing input 0x0D two times , it is not switching to shell mode.
Do i need to just write 0X0D two times on terminal or am i missing something?
I am not able to switch to shell mode using 0x0D.
Please suggest me how to achieve this.
Regards
Akansha
Hi
Not all terminal emulators work the same, sometimes you have a similar problem.
Try using Putty to me it worked successfully.
best regards
