Is there any way to use various networks in the same application and allowing all the tags to automatically “jump” from one to another??
Thank you!!
Thank you!!
Hi ElectroAaaron,
This is not supported by default. You could maybe try to implement it in the user application space, it could be feasible using the api dwm_panid_set and dwm_status_get. For example, is the status is node disconnected, you can change pan_id until it is connected. I haven’t tried it myself so not sure it works, as well as probable not beeing the most optimized system from a power perspective.
Hope it helps,
Hope it helps,
