I’m doing a project in which I want to use 2 DWM1001 Development boards to send and receive live video respectively. The video will be captured using a Raspberry Pi camera module. Is this possible? I was thinking of seeting up a Gateway to do this.
The maximum data rate is 6.8Mb/s. Once you allow for packet header overheads etc… the usable data rate will be a little lower but it should be possible to get several Mb/s of usable data through a point to point link.
However that is not the use case that these parts are intended for so don’t expect the off the shelf drivers and libraries to be of much help, they won’t be designed with bulk data transfer in mind.
