I want just to know if I can use the DecaW development kit from terminal only without installing any additional packages, by connecting one of them to the serial port and leave the other switched on in the room. I tried to listen from the serial port putting the one connected in a listener passive state from the command line. However, using the les
command I am not able to see any info.
I was reading your datasheet and guides and it seems that I can only interface with them through the android app even when I am purely using the terminal. If I am wrong could you please give me a link or a documentation where can I look up? Because maybe I was not able to find it. Thank you in advance
