I tried to generate my own executable from TREK1000 source code and I cannot… Is there any document that explains what I need to do to generate the executable?
I want to make some modifications to your interface to show for example the ranging values.
Thanks in advance.
Leticia.
Could I ask what TREK SW you’re using? If version 2.10 the IDE Coocox 1.7.8 is required. If using SW version 2.25 than CubeMX .
In case you’re using CubeMX. Included in the downloaded zip file are 2 documents included which could be useful 01_InstallationOfTheToolsAndDrivers and 02_PortingToSTWorkbench
/L
I think I didn’t explain correctly. I am not talking about to generate the binary file for the ARM microcontroller. But about the GUI for the PC.
We are using TREK1000 Source Code 2.10 Release (DecaRangeRTLS_PC_3p6). We can generate the executable GUI with QT framework in debug mode, but we are having problems in generating the release version. Could this be because we need to use a 32-bit computer?
Thanks,
Leticia.
