What is the reason that my tag is unable to calculate the location when it sees 3 anchors?tag_no_position|690x289
Hi @filipbaza
are you sure that the output os not cut of by the size of the terminal window?
However it might not be able to calculate its position when the ranges does not fit to any solution → check anchors position and their XYZ setting.
Cheers
JK
