Rerun simulation quirk
From the Work panel selecting Run, as one would expect, it does the task. Recently, I’m experiencing that if Run is refreshed from the Work panel, and also from the View panel, the wave form output changes significantly. This is disconcerting, do I trust the first output or the refeshed output? For now I’m closing the View Panel and only using Run simu from the Work panel.
Hitting Run and you may get different output waveform without any change of .qsch?
I recall I experienced that before but the case has been resolved. If you can replicate this issue with a particular schematic, consider sharing it here. Your membership level should allow you to upload .qsch.
Ah, I’ve forced an update and it is solved. Many thanks.
Regards
