Hi!
I’m trying to change (manually) the power of the device using the dwt_configuretxrf function, based on the recommended values. Also, found on the web few people who had done the same.
I also print first path power level using the diagnostics.
It seems it does not change (first path power level), while changing the power configuration.
- How so? I’m trying to understand if I’m doing something wrong.
- Should I change the power in both Tx, Rx?
Thanks!
