The ACC_MEM (as described in the UM)… should be read out and converted into signed 16-bit real/imaginary (complex) samples. NOTE - when reading out ACC_MEM the 1st byte will always be a dummy byte (0) and should be ignored. E.g. to read 1 complex sample, you should provide an array of 5 bytes to dwt_readaccdata, the 1st byte should be discarded.
I read out the all data of register ACC_MEM again according your advice. At same time, I plot the CIR graph[color=#333333]-sqrt(Imag^2+Real^2)[/color] according data. I find my graph is different from standard graph. Could you tell me why.
I presume you are reading the ACC_MEM after a frame reception, can you attach raw bytes? I suspect you are not converting raw bytes to 16-bit signed numbers.
