Hello Everyone,
Now I’m testing several algorithms to estimate the position of my tag from a set of distance measurements extracted from my DWM1001 network.
In order to evaluate these algorithms, I need to know the precise PHYSICAL distance between the tag and each anchor. My question is between which points exactly on the plastic enclosure this physical measurement should be done (I image maybe the top edge a bit towards the left side as that’s where the center of the antenna is)?
Thank you for your help!
