Hi everyone,
is it possible with the current firmware or the next release to detect if an anchor does not work anymore or if it has been moved ?
With and without a gateway.
Thank you in advance for your help
regarding to the manual there is no direct way how to do it. In small networks where every AN listen each AN you can run command “la” in anchor shell which returns you the actual anchor list (in range) so you can periodically scan for anchor list.
Personally Im expecting this feature in R2 release as it should bring IoT connectivity features. How ever regarding to the doc (in docs are some pictures with ANR and BN) there will be probably some limits - AN must be in range of ANR? So it will probably not cover the whole area. Lets wait for R2.
Regards
drg
