Dear all
Please see the attached, which includes technical questions and site information for MEDK1001.
I would like to install 25 Anchors, 6 Tages and one Listener for one path to the building (20m x 90 m) and 1F and 2F of the building.
I would like to collect real time location data from the listener which is located at 2F.
Your comments and advice must be very helpful for me to develop the system.
Thanks in advance for your assistance.
Best regards,
KIM
Hello Sam,
here are a couple of links to other threads that i found useful in the case of wide area network:
this suggests that the listener has to be in range with all tags and anchors that it needs to get the data from, therefor you might need more than 1 listener.
https://www.decawave.com/decaforum/showthread.php?tid=1362&pid=3854#pid3854
and this suggests that you can only connect 16 anchors to each listener.
https://www.decawave.com/decaforum/showthread.php?tid=619&highlight=large+network
Hope this helps.
Best Regards,
Haitham
The reason your other PCs cannot receive signal is that they are not in range of the tag. Use centerlized location for saving tags position, perhaps a server. Since Listner is nothing but something that requests Tags for their location they must be within distance of the tag.
Interface a device using SPI with the board and upload that data to server using wifi
haitham.b:
Dear all
Best regards,
KIM
Hello Sam,
Decawave is now part of Qorvo
Hope this helps.
Best Regards,
Haitham
[hr]
Dear all
Best regards,
KIM
Hello Sam,
Hope this helps.
Best Regards,
Haitham
Thank you so much for your kindness.
[hr]
ifithegr8:
Thank you so much for your information and I now get to know much better about MDEK.
