When using 2 Tags and 10 Anchors, [color=#000000][size=small][font=sans-serif]MDEK1001 automatically decides which anchor-set to range with.[/font][/size][/color]
[color=#000000][size=small][font=sans-serif]In our application, especially for corridor shaped areas with obstacles, it is necessary to define target anchors.[/font][/size][/color]
[color=#000000][size=small][font=sans-serif]Is there any e.g. UART command to dynamically tell each Tag which anchor to use?[/font][/size][/color]
Thank you for the answer.
So, C codes should be added for this purpose or it is inherent limitation of system?
(In my opinion, this is a very big limitation. In real industrial conditions, with lots of obstacles around, Tag may not always choose best anchors automatically. Also for data fusion engines, switching anchors should be controlled)
