Is it possible to get distance from anchor with DWM1001 PANS Release 2?
yes configuing a bridge node
Best Regards
CostaT
set anchor or tag to passive mode?
zyliu
configuring a bridge.
see more in the forum.
If you have a raspberry pi connected to a beacon (or any other computer) via USB, you can get the location of that beacon using the ‘lec’ command, along with the distance to each of the anchors it is connected to. You don’t need a gateway in this case.
