Investigating issue in Qspice when using LTspice symbols for Vacuum Tubes (X type)
I found a couple of 7199 vacuum tube symbols in the LTspice symbol database. For this tube the Pentode and Triode have been separated into two Symbols. I tried using them in my existing schematic. They needed to be tweaked so I copied them. The news ones have been erroring and I’ve noted that the netlist is adding an ’ character which I cannot find in the Symbol binary test files nor the Library .SUBCKT files. Starting from this observation I think the issue is a Windows Notepad issue, a text file encoding issue or something embedded either in my Windows 11 OS or the originating LTspice OS whatever was used to generate the Symbol Library text file. I’ll add the original LTspice Library files and my new modiifed ones plus my schematic.
Here is LTspice model and schematic from diyaudio.com, ported over to QSPICE.
I noticed that 7199_P.qsym is harder to converge in SPICE.
As a reminder, I don’t have hands-on experience with vacuum tubes—I’m simply replicating working examples to verify that they simulate in QSPICE.
I quote their original source (link) in symbol description or in schematic textbox.
symbol : from diyaudio.com
Triode : 7199T.qsym (1.1 KB)
Pentode : 7199P.qsym (2.1 KB)
Pentode : 7199_P.qsym (2.9 KB)
circuit example
7199P gain test.qsch (334.2 KB)
7199_P gain test.qsch (335.0 KB)
I cannot add the files to support this post, don’t know how.
You should be able to upload it, provided the forum allows that file extension
I’m clearly a newbie, do not see that menu. Will check on desktop pc, am on mobile now.
Dynaco ST-70_r2.qsch (12.1 KB)
7199P.qsym (709 Bytes)
7199T.qsym (649 Bytes)
7199P.txt (1.3 KB)
7199T.txt (737 Bytes)
7199 Pentode.txt (1.1 KB)
7199 Triode.txt (558 Bytes)
Dynaco ST-70_r2.cir (806 Bytes)
This one is set up with the correct subcircuit symbol. However, you still need to add your simulation directive.
Dynaco ST-70_r3.qsch (12.2 KB)
KSKelvin - is the symbol property for the Pentode and Triode for Name set to X1 and X2 only in the schematic, or is it also set in each Symbol file too? (or if I change in either context will it auto-populate in the other context, Symbol / Schematic)?
KSKelvin,
The changes worked. Name, attribute and I added the simulation directive.
Thanks for the assist!
Mike
