Implementing APS006
While coding the APS006 part 3, it is not clear what noise floor should be used for Luep.
The noise figures calculated as rx_diag->stdNoise * LDE_cfg_value (bottom 5 bits) seem not to correlate with the magnitude values calculated from the accumulator samples as suggested.
Is there a worked example for this?
Magn Question.pdf (97.3 KB)
Hi Nick,
I hope the attachment answers your question.
Not sure what other example you may refer to. We have code example (ex_02c_rx_diagnostics) as part of the example API.
Regards
/Leo
