Hello,
Thank you for choosing Qorvo UWB. We’re happy to assist you.
Based on the current DW3_QM33_SDK_v1.1.0 available on our website, here’s how you can capture CIR logs during Two Way Ranging (TWR):
- Firmware:
Ensure your firmware is UCI (UWB Command/Communication Interface) based. - UQT Tool:
Use the UQT (UWB Qorvo Tool), which provides Python-based wrapper functions for UCI transactions with the Qorvo UWB chip.
- Please refer to the UWB-Qorvo-Tools-guide.pdf for installation prerequisites and setup instructions.
- Running TWR with CIR Logging:
After installing the required Python packages for UQT, you can start a TWR session with CIR logging enabled:
- See section 6.2 “FiRa Diagnostics” in uwb-uci-messages-api-R12.7.0-405.pdf for more details.
- In your terminal, type
-h
to view available options:
run_fira_twr -h
- For example, to enable CIR diagnostics:
run_fira_twr --en-diag --diag-fields='cir' -p {COM_PORT}
- Once TWR is successful between the two devices, you will see the CIR data as needed.
We hope this helps!
Thank you for your patience and for using Qorvo UWB.
