How do i get the channel impulse responce for the dwm1001?
If you are talking about MDEK SW package - nohow.
If you are talking about DWM1001 module on its own, you can write your own SW, which will read and send over the communication interface 4KB of the channel.
I wrote a script that opens a serial port in python to the module on its own?
How can i scrape the amplitudes and times in software? any hints?
Thanks alliv
As I told you before: on MDEK no how. Read: you cannot do that.
Yoü need to implement the required functionality on the layer where you have no access.
You can try to hack this from the user-space application, but that would might not be a correct data.
The only way for you to see a channel impulse response is to purchase EVK1000 kit; download the pack for evk1000, which has the DecaRanging PC application, then set one board as the listener and display the channel.
Regards.
