Hello, I Have 2 Modules: 1 setup as an anchor and 1 setup as a tag(from my windows pc), But Now, I need to Display data on my raspberry pi. But the problem That I am having is that, I can’t seem to find what’s serial port adress of the module on raspbian. Also, Should I connect module with USB or 2x13 Pin adapter?
Hi @xvichie
this depends on the way how you connect the DWM1001-dev board to the RPI. If over USB then the seral name should be something like /dev/ttyACM0 . If you connect it via header see my answer here: How to use bluetooth mode in Programming language(Python,Javascript)? - #6 by leapslabs
Cheers
JK
