The project uses QSpice QUX.exe and QSpice64/80.exe for all of the back-end stuff. So, yes, you can run the sim. Yes, the Waveform viewer displays the traces progressively. Yes, you can click nets on the GUI to add traces to the Waveform viewer.
Not sure what you’re asking for (3). If you’re asking whether we can disable the Waveform viewer, well, we control the interface – see the Appendix I Help topic. So, yes, we could disable the Waveform viewer or increase/reduce the update interval.
Similarly, (4) is unclear. If what you’re asking is can we wait to launch the Waveform viewer until the sim completes, well, currently the code can close the waveform viewer and reopen it – where reopen really means to load/display the .qraw file. So, yeah, don’t display until complete should be doable.
Did that answer your questions?
