hi,
i have the same issue, and i tried to do the steps above !
thanks for help.
Hi @leapslabs
i have the same issue and my Kernel is 4.14.50-v7+ .
how could i fix this, the gateway was working so no problems on installation or soldering, i just shutdown the pi some days then chnge it from bridge to gateway then like this photo >>>
thanks.
please send the output of these commands on your Raspberry PI:
$ uname -a
$ lsmod
$ ps ax | grep dwm
$ dmesg
Cheers,
TDK
Does the DRTLS raspbian R2.0 image downloaded from Decawave work with the Raspberry Pi 3a+ ?
On power up of the Raspberry Pi 3a+ with the image on 32GB scandisk SD card (flashed using balenaEtcher), the red led is on but no flashing green led.
Hi Eclaw,
The image is targeting raspberry pi 3b as specified in the documentation. We haven’t tried on different platform and it may not work.
Thanks,
I have the same issue where the web manager displays only the gateways and not the anchors and tags present in the network.
I have tried all the methods which has been mentioned above but the issue still persists.
Thanks,
Prajval
1、using Raspberry pi 3 model B V1.2 2015.
2、fw2
minicom in
dwm> si
[000010.160 INF] sys: fw2 fw_ver=x01030001 cfg_ver=x00010700
[000010.160 INF] uwb0: panid=x1234 addr=xDECAB6F0B2C02D68
[000010.170 INF] mode: bn (act,-)
[000010.170 INF] uwbmac: disconnected
[000010.170 INF] enc: off
[000010.180 INF] ble: addr=CE:6C:B0:1A:49:23
3、using the DRTLS_raspbian_R2.0 from release 2 files.
4、
5、pi@raspberrypi:~ $ uname -r
4.14.50-v7+
6、pi@raspberrypi:~ $ ls -la /lib/modules/4.14.50-v7+/dwm.ko
-rw-r–r-- 1 root root 96772 Feb 7 2019 /lib/modules/4.14.50-v7+/dwm.ko
pi@raspberrypi:~ $ modinfo /lib/modules/4.14.50-v7+/dwm.ko
filename: /lib/modules/4.14.50-v7+/dwm.ko
alias: spi:dwm
license: GPL
description: DWM Gateway SPI master
author: Jan Faber, jan.faber@leapslabs.com
srcversion: 7901FD32EB4D23209223957
alias: of:NTCspidwmC*
alias: of:NTCspidwm
alias: of:NTClineartechnology,ltc2488C*
alias: of:NTCrohm,dh2228fvC*
depends:
vermagic: 4.14.50-v7+ SMP mod_unload modversions ARMv7 p2v8
7、pi@raspberrypi:~ $ cat /proc/iomem
00000000-00000000 : System RAM
00000000-00000000 : Kernel code
00000000-00000000 : Kernel data
00000000-00000000 : dwc_otg
00000000-00000000 : /soc/dma@7e007000
00000000-00000000 : /soc/vchiq
00000000-00000000 : /soc/mailbox@7e00b880
00000000-00000000 : /soc/watchdog@7e100000
00000000-00000000 : /soc/cprman@7e101000
00000000-00000000 : /soc/gpio@7e200000
00000000-00000000 : /soc/serial@7e201000
00000000-00000000 : /soc/mmc@7e202000
00000000-00000000 : /soc/spi@7e204000
00000000-00000000 : /soc/thermal@7e212000
00000000-00000000 : /soc/aux@0x7e215000
00000000-00000000 : /soc/serial@7e215040
00000000-00000000 : /soc/mmc@7e300000
8、pi@raspberrypi:~ $ find /proc/device-tree/ -name “spi”
/proc/device-tree/overrides/spi
/proc/device-tree/symbols/spi2
/proc/device-tree/symbols/spi0
/proc/device-tree/symbols/spidev1
/proc/device-tree/symbols/spi0_gpio35
/proc/device-tree/symbols/spi0_pins
/proc/device-tree/symbols/spi0_gpio7
/proc/device-tree/symbols/spi1
/proc/device-tree/symbols/spi1_gpio16
/proc/device-tree/symbols/spi2_gpio40
/proc/device-tree/symbols/spi0_cs_pins
/proc/device-tree/symbols/spidwm0
/proc/device-tree/soc/gpio@7e200000/spi0_gpio35
/proc/device-tree/soc/gpio@7e200000/spi0_pins
/proc/device-tree/soc/gpio@7e200000/spi0_gpio7
/proc/device-tree/soc/gpio@7e200000/spi1_gpio16
/proc/device-tree/soc/gpio@7e200000/spi2_gpio40
/proc/device-tree/soc/gpio@7e200000/spi0_cs_pins
/proc/device-tree/soc/spi@7e204000
/proc/device-tree/soc/spi@7e204000/spidev@1
/proc/device-tree/soc/spi@7e204000/spidev@1/spi-max-frequency
/proc/device-tree/soc/spi@7e204000/spidwm@0
/proc/device-tree/soc/spi@7e204000/spidwm@0/spi-max-frequency
/proc/device-tree/soc/spi@7e215080
/proc/device-tree/soc/spi@7e2150c0
/proc/device-tree/aliases/spi2
/proc/device-tree/aliases/spi0
/proc/device-tree/aliases/spi1
9、pi@raspberrypi:~ $ uname -a
Linux raspberrypi 4.14.50-v7+ #1122 SMP Tue Jun 19 12:26:26 BST 2018 armv7l GNU/Linux
10、pi@raspberrypi:~ $ cat /proc/cpuinfo
processor : 0
model name : ARMv7 Processor rev 4 (v7l)
BogoMIPS : 38.40
Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm crc32
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
processor : 1
BogoMIPS : 38.40
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
processor : 2
BogoMIPS : 38.40
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
processor : 3
BogoMIPS : 38.40
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
Hardware : BCM2835
Revision : a02082
Serial : 00000000e7d9e57d
11、pi@raspberrypi:~ $ insmod /lib/modules/4.14.50-v7+/dwm.ko
insmod: ERROR: could not insert module /lib/modules/4.14.50-v7+/dwm.ko: Operation not permitted
12、pi@raspberrypi:~ $ dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.14.50-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1122 SMP Tue Jun 19 12:26:26 BST 2018
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Rev 1.2
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] cma: Reserved 8 MiB at 0x3ac00000
[ 0.000000] On node 0 totalpages: 242688
[ 0.000000] free_area_init_node: node 0, pgdat 80c85000, node_mem_map ba3a1000
[ 0.000000] Normal zone: 2133 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 242688 pages, LIFO batch:31
[ 0.000000] percpu: Embedded 17 pages/cpu @ba34a000 s38720 r8192 d22720 u69632
[ 0.000000] pcpu-alloc: s38720 r8192 d22720 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 240555
[ 0.000000] Kernel command line: 8250.nr_uarts=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=tty1 root=PARTUUID=c049f471-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 940236K/970752K available (7168K kernel code, 575K rwdata, 2072K rodata, 1024K init, 706K bss, 22324K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xbb800000 - 0xff800000 (1088 MB)
lowmem : 0x80000000 - 0xbb400000 ( 948 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x80800000 (8160 kB)
.init : 0x80b00000 - 0x80c00000 (1024 kB)
.data : 0x80c00000 - 0x80c8fef4 ( 576 kB)
.bss : 0x80c96f40 - 0x80d478b4 ( 707 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 25253 entries in 75 pages
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000019] Switching to timer-based delay loop, resolution 52ns
[ 0.000261] Console: colour dummy device 80x30
[ 0.000278] console [tty1] enabled
[ 0.000305] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=192000)
[ 0.000321] pid_max: default: 32768 minimum: 301
[ 0.000640] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000654] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001586] Disabling memory control group subsystem
[ 0.001667] CPU: Testing write buffer coherency: ok
[ 0.002058] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002435] Setting up static identity map for 0x100000 - 0x10003c
[ 0.002553] Hierarchical SRCU implementation.
[ 0.003183] smp: Bringing up secondary CPUs …
[ 0.003861] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.004608] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.005337] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.005441] smp: Brought up 1 node, 4 CPUs
[ 0.005452] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.005457] CPU: All CPU(s) started in HYP mode.
[ 0.005461] CPU: Virtualization extensions available.
[ 0.006317] devtmpfs: initialized
[ 0.016207] random: get_random_u32 called from bucket_table_alloc+0xfc/0x24c with crng_init=0
[ 0.016934] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.017155] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.017173] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.017733] pinctrl core: initialized pinctrl subsystem
[ 0.018469] NET: Registered protocol family 16
[ 0.021164] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.026003] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.026011] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.026208] Serial: AMBA PL011 UART driver
[ 0.027823] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.028279] uart-pl011 3f201000.serial: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
[ 0.060118] bcm2835-dma 3f007000.dma: DMA legacy API manager at bb813000, dmachans=0x1
[ 0.061529] SCSI subsystem initialized
[ 0.061754] usbcore: registered new interface driver usbfs
[ 0.061811] usbcore: registered new interface driver hub
[ 0.061896] usbcore: registered new device driver usb
[ 0.070090] raspberrypi-firmware soc:firmware: Attached to firmware from 2018-06-07 15:31
[ 0.071475] clocksource: Switched to clocksource arch_sys_counter
[ 0.148381] VFS: Disk quotas dquot_6.6.0
[ 0.148465] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.148651] FS-Cache: Loaded
[ 0.148851] CacheFiles: Loaded
[ 0.157629] NET: Registered protocol family 2
[ 0.158349] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.158459] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.158645] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.158774] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.158818] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.159044] NET: Registered protocol family 1
[ 0.159495] RPC: Registered named UNIX socket transport module.
[ 0.159501] RPC: Registered udp transport module.
[ 0.159506] RPC: Registered tcp transport module.
[ 0.159511] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.161043] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 0.163791] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ 0.171739] FS-Cache: Netfs ‘nfs’ registered for caching
[ 0.172334] NFS: Registering the id_resolver key type
[ 0.172360] Key type id_resolver registered
[ 0.172365] Key type id_legacy registered
[ 0.172380] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 0.174246] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 0.174369] io scheduler noop registered
[ 0.174376] io scheduler deadline registered (default)
[ 0.174647] io scheduler cfq registered
[ 0.174654] io scheduler mq-deadline registered
[ 0.174660] io scheduler kyber registered
[ 0.177333] BCM2708FB: allocated DMA memory fad10000
[ 0.177360] BCM2708FB: allocated DMA channel 0 @ bb813000
[ 0.185886] Console: switching to colour frame buffer device 82x26
[ 0.191041] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
[ 0.192411] bcm2835-rng 3f104000.rng: hwrng registered
[ 0.192548] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 0.192994] vc-sm: Videocore shared memory driver
[ 0.193264] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 0.202727] brd: module loaded
[ 0.211268] loop: module loaded
[ 0.211280] Loading iSCSI transport class v2.0-870.
[ 0.212033] libphy: Fixed MDIO Bus: probed
[ 0.212131] usbcore: registered new interface driver lan78xx
[ 0.212188] usbcore: registered new interface driver smsc95xx
[ 0.212203] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.440275] Core Release: 2.80a
[ 0.440283] Setting default values for core params
[ 0.440316] Finished setting default values for core params
[ 0.640566] Using Buffer DMA mode
[ 0.640572] Periodic Transfer Interrupt Enhancement - disabled
[ 0.640576] Multiprocessor Interrupt Enhancement - disabled
[ 0.640583] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.640592] Dedicated Tx FIFOs mode
[ 0.640981] WARN::dwc_otg_hcd_init:1046: FIQ DMA bounce buffers: virt = 0xbad04000 dma = 0xfad04000 len=9024
[ 0.641007] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 0.641014] dwc_otg: Microframe scheduler enabled
[ 0.641067] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x805e7d20
[ 0.641078] WARN::hcd_init_fiq:460: FIQ ASM at 0x805e8088 length 36
[ 0.641090] WARN::hcd_init_fiq:486: MPHI regs_base at 0xbb87e000
[ 0.641145] dwc_otg 3f980000.usb: DWC OTG Controller
[ 0.641176] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 0.641208] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[ 0.641255] Init: Port Power? op_state=1
[ 0.641260] Init: Power Port (0)
[ 0.641479] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.641490] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.641498] usb usb1: Product: DWC OTG Controller
[ 0.641506] usb usb1: Manufacturer: Linux 4.14.50-v7+ dwc_otg_hcd
[ 0.641514] usb usb1: SerialNumber: 3f980000.usb
[ 0.642111] hub 1-0:1.0: USB hub found
[ 0.642156] hub 1-0:1.0: 1 port detected
[ 0.642680] dwc_otg: FIQ enabled
[ 0.642685] dwc_otg: NAK holdoff enabled
[ 0.642690] dwc_otg: FIQ split-transaction FSM enabled
[ 0.642700] Module dwc_common_port init
[ 0.642918] usbcore: registered new interface driver usb-storage
[ 0.643078] mousedev: PS/2 mouse device common for all mice
[ 0.643146] IR NEC protocol handler initialized
[ 0.643151] IR RC5(x/sz) protocol handler initialized
[ 0.643156] IR RC6 protocol handler initialized
[ 0.643162] IR JVC protocol handler initialized
[ 0.643167] IR Sony protocol handler initialized
[ 0.643172] IR SANYO protocol handler initialized
[ 0.643177] IR Sharp protocol handler initialized
[ 0.643182] IR MCE Keyboard/mouse protocol handler initialized
[ 0.643187] IR XMP protocol handler initialized
[ 0.643860] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[ 0.644111] bcm2835-cpufreq: min=600000 max=1200000
[ 0.644456] sdhci: Secure Digital Host Controller Interface driver
[ 0.644460] sdhci: Copyright(c) Pierre Ossman
[ 0.644799] mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
[ 0.645107] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[ 0.645202] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.646577] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.646749] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.646871] usbcore: registered new interface driver usbhid
[ 0.646875] usbhid: USB HID core driver
[ 0.647575] vchiq: vchiq_init_state: slot_zero = bad80000, is_master = 0
[ 0.648911] [vc_sm_connected_init]: start
[ 0.657597] [vc_sm_connected_init]: end - returning 0
[ 0.658171] Initializing XFRM netlink socket
[ 0.658193] NET: Registered protocol family 17
[ 0.658276] Key type dns_resolver registered
[ 0.658779] Registering SWP/SWPB emulation handler
[ 0.659349] registered taskstats version 1
[ 0.665214] uart-pl011 3f201000.serial: cts_event_workaround enabled
[ 0.665292] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[ 0.666777] 3f215040.serial: ttyS0 at MMIO 0x0 (irq = 166, base_baud = 31250000) is a 16550
[ 0.667635] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[ 0.667643] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[ 0.722096] sdhost: log_buf @ bad07000 (fad07000)
[ 0.757866] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 0.759437] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.761004] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.763796] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 0.801491] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 0.802488] of_cfs_init
[ 0.802626] of_cfs_init: OK
[ 0.803147] Waiting for root device PARTUUID=c049f471-02…
[ 0.839937] random: fast init done
[ 0.861659] Indeed it is in host mode hprt0 = 00021501
[ 0.939381] mmc1: new high speed SDIO card at address 0001
[ 0.961964] mmc0: host does not support reading read-only switch, assuming write-enable
[ 0.965731] mmc0: new high speed SDHC card at address aaaa
[ 0.966150] mmcblk0: mmc0:aaaa SC16G 14.8 GiB
[ 0.968569] mmcblk0: p1 p2
[ 0.985348] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 0.985356] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 1.071505] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 1.071622] Indeed it is in host mode hprt0 = 00001101
[ 1.245237] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
[ 1.245374] EXT4-fs (mmcblk0p2): 1 orphan inode deleted
[ 1.245381] EXT4-fs (mmcblk0p2): recovery complete
[ 1.257887] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.257942] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.266691] devtmpfs: mounted
[ 1.269672] Freeing unused kernel memory: 1024K
[ 1.311784] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 1.311798] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.312481] hub 1-1:1.0: USB hub found
[ 1.312570] hub 1-1:1.0: 5 ports detected
[ 1.631535] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 1.647167] systemd[1]: System time before build time, advancing clock.
[ 1.761799] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 1.761815] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.764666] smsc95xx v1.0.6
[ 1.780050] NET: Registered protocol family 10
[ 1.781238] Segment Routing with IPv6
[ 1.792714] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.809947] random: systemd: uninitialized urandom read (16 bytes read)
[ 1.821337] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[ 1.821967] systemd[1]: Detected architecture arm.
[ 1.822988] systemd[1]: Set hostname to .
[ 1.856180] random: systemd: uninitialized urandom read (16 bytes read)
[ 1.857748] smsc95xx 1-1.1:1.0 eth0: register ‘smsc95xx’ at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:d9:e5:7d
[ 1.872949] random: systemd-cryptse: uninitialized urandom read (16 bytes read)
[ 2.272551] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 2.273322] systemd[1]: Listening on udev Control Socket.
[ 2.274052] systemd[1]: Created slice User and Session Slice.
[ 2.274361] systemd[1]: Listening on Journal Socket (/dev/log).
[ 2.274568] systemd[1]: Listening on udev Kernel Socket.
[ 2.274705] systemd[1]: Reached target Swap.
[ 2.274897] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 2.452163] i2c /dev entries driver
[ 2.464402] dwm: no symbol version for module_layout
[ 2.464429] dwm: loading out-of-tree module taints kernel.
[ 2.689799] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 2.770559] systemd-journald[103]: Received request to flush runtime journal from PID 1
[ 3.221199] dwm spi0.0: loading
[ 3.221406] dwm spi0.0: DWM1001 TWR Real Time Location System
[ 3.221414] dwm spi0.0:
[ 3.221423] dwm spi0.0: Copyright : 2016-2019 LEAPS and Decawave
[ 3.221440] dwm spi0.0: License : Please visit DWM1001, DW10001-DEV and MDEK1001 Documents, Source Code, Android Application & R2.0 Firmware Image - Decawave
[ 3.221451] dwm spi0.0: Compiled : Feb 4 2019 12:36:58
[ 3.286741] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 3.292535] bcm2835_alsa bcm2835_alsa: card created with 8 channels
[ 3.452963] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
[ 3.466033] brcmfmac: brcmf_fw_map_chip_to_name: using brcm/brcmfmac43430-sdio.bin for chip 0x00a9a6(43430) rev 0x000001
[ 3.466369] usbcore: registered new interface driver brcmfmac
[ 3.582669] dwm spi0.0: bridge is not connected to UWB network
[ 3.582685] dwm spi0.0: bridge ok
[ 3.701082] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Oct 23 2017 03:55:53 version 7.45.98.38 (r674442 CY) FWID 01-e58d219f
[ 3.702217] brcmfmac: brcmf_c_preinit_dcmds: CLM version = API: 12.2 Data: 7.11.15 Compiler: 1.24.2 ClmImport: 1.24.1 Creation: 2014-05-26 10:53:55 Inc Data: 9.10.39 Inc Compiler: 1.29.4 Inc ClmImport: 1.36.3 Creation: 2017-10-23 03:47:14
[ 5.080757] uart-pl011 3f201000.serial: no DMA platform data
[ 5.538720] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 5.538749] brcmfmac: power management disabled
[ 5.726455] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 6.032761] smsc95xx 1-1.1:1.0 eth0: hardware isn’t capable of remote wakeup
[ 6.032937] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 6.408117] dwm spi0.0: PAN ID changed by user to x1234
[ 6.408128] dwm spi0.0: encryption key changed by user
[ 6.408133] dwm spi0.0: encryption configuration changed by user
[ 6.408138] dwm spi0.0: firmware update configuration changed by user
[ 6.408142] dwm spi0.0: UWB mode configuration changed by user
[ 6.408146] dwm spi0.0: reinitialize …
[ 6.557916] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 9.569350] Bluetooth: Core ver 2.22
[ 9.569441] NET: Registered protocol family 31
[ 9.569450] Bluetooth: HCI device and connection manager initialized
[ 9.569471] Bluetooth: HCI socket layer initialized
[ 9.569489] Bluetooth: L2CAP socket layer initialized
[ 9.569524] Bluetooth: SCO socket layer initialized
[ 9.593672] Bluetooth: HCI UART driver ver 2.3
[ 9.593694] Bluetooth: HCI UART protocol H4 registered
[ 9.593708] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 9.594250] Bluetooth: HCI UART protocol Broadcom registered
[ 9.766065] dwm spi0.0: setting bridge PAN ID to x1234 …
[ 9.811235] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 9.811245] Bluetooth: BNEP filters: protocol multicast
[ 9.811258] Bluetooth: BNEP socket layer initialized
[ 9.821547] dwm spi0.0: setting encryption key on gateway
[ 9.888000] Bluetooth: RFCOMM TTY layer initialized
[ 9.888026] Bluetooth: RFCOMM socket layer initialized
[ 9.888043] Bluetooth: RFCOMM ver 1.11
[ 9.953184] dwm spi0.0: invalid bridge config detected = 0x2812
[ 9.953192] dwm spi0.0: configuring bridge …
[ 10.056391] dwm spi0.0: dwm_cfg_anchor_set failed, error 255
[ 10.056403] dwm spi0.0: reseting bridge
[ 10.082874] dwm spi0.0: dwm_reset failed, error -14
[ 10.082884] dwm spi0.0: bridge can’t be initialized, error -14
[ 10.965681] fuse init (API version 7.26)
[ 13.352637] dwm spi0.0: decode TLV failed, error 3 t:255 l:1
[ 13.352652] dwm spi0.0: dwm_panid_get failed, error -12
[ 13.352658] dwm spi0.0: reseting bridge
[ 14.471537] dwm spi0.0: bridge can’t be initialized, error -14
[ 17.872565] dwm spi0.0: invalid bridge config detected = 0x2812
[ 17.872578] dwm spi0.0: configuring bridge …
[ 17.975942] dwm spi0.0: reseting bridge
[ 19.031524] dwm spi0.0: bridge ok
[ 49.111489] dwm spi0.0: bridge not responding
[ 49.111516] dwm spi0.0: reinitialize …
[ 52.512606] dwm spi0.0: invalid bridge config detected = 0x2812
[ 52.512618] dwm spi0.0: configuring bridge …
[ 52.616159] dwm spi0.0: reseting bridge
[ 52.642724] dwm spi0.0: dwm_reset failed, error 0
[ 52.642733] dwm spi0.0: bridge can’t be initialized, error -14
[ 56.032610] dwm spi0.0: invalid bridge config detected = 0x2812
[ 56.032623] dwm spi0.0: configuring bridge …
[ 56.135548] dwm spi0.0: reseting bridge
[ 56.162727] dwm spi0.0: dwm_reset failed, error 0
[ 56.162736] dwm spi0.0: bridge can’t be initialized, error -14
[ 59.552593] dwm spi0.0: invalid bridge config detected = 0x2812
[ 59.552605] dwm spi0.0: configuring bridge …
[ 59.655506] dwm spi0.0: decode TLV failed, error -1 t:255 l:64
[ 59.655516] dwm spi0.0: dwm_cfg_anchor_set failed, error -12
[ 59.655522] dwm spi0.0: reseting bridge
[ 59.682725] dwm spi0.0: dwm_reset failed, error -14
[ 59.682734] dwm spi0.0: bridge can’t be initialized, error -14
[ 63.072607] dwm spi0.0: invalid bridge config detected = 0x2812
[ 63.072620] dwm spi0.0: configuring bridge …
[ 63.175948] dwm spi0.0: reseting bridge
[ 63.202559] dwm spi0.0: decode TLV failed, error 3 t:255 l:1
[ 63.202574] dwm spi0.0: dwm_reset failed, error 0
[ 63.202579] dwm spi0.0: bridge can’t be initialized, error -14
[ 66.506131] random: crng init done
[ 66.506146] random: 7 urandom warning(s) missed due to ratelimiting
[ 66.592598] dwm spi0.0: invalid bridge config detected = 0x2812
[ 66.592611] dwm spi0.0: configuring bridge …
[ 66.695850] dwm spi0.0: dwm_cfg_anchor_set failed, error 255
[ 66.695859] dwm spi0.0: reseting bridge
[ 66.722564] dwm spi0.0: decode TLV failed, error 3 t:192 l:1
[ 66.722576] dwm spi0.0: dwm_reset failed, error -14
[ 66.722581] dwm spi0.0: bridge can’t be initialized, error -14
[ 70.112536] dwm spi0.0: invalid bridge config detected = 0x2812
[ 70.112549] dwm spi0.0: configuring bridge …
[ 70.215938] dwm spi0.0: reseting bridge
[ 71.271415] dwm spi0.0: bridge ok
[ 101.591048] dwm spi0.0: bridge not responding
[ 101.591078] dwm spi0.0: reinitialize …
[ 104.992119] dwm spi0.0: invalid bridge config detected = 0x2812
[ 104.992131] dwm spi0.0: configuring bridge …
[ 105.097665] dwm spi0.0: decode TLV failed, error -1 t:255 l:255
[ 105.097678] dwm spi0.0: dwm_cfg_anchor_set failed, error -12
[ 105.097683] dwm spi0.0: reseting bridge
[ 105.122375] dwm spi0.0: dwm_reset failed, error -14
[ 105.122382] dwm spi0.0: bridge can’t be initialized, error -14
[ 108.512104] dwm spi0.0: invalid bridge config detected = 0x2812
[ 108.512116] dwm spi0.0: configuring bridge …
[ 108.615522] dwm spi0.0: reseting bridge
[ 109.671056] dwm spi0.0: bridge ok
[ 139.991378] dwm spi0.0: bridge not responding
[ 139.991412] dwm spi0.0: reinitialize …
[ 143.392589] dwm spi0.0: invalid bridge config detected = 0x2812
[ 143.392601] dwm spi0.0: configuring bridge …
[ 143.496293] dwm spi0.0: dwm_cfg_anchor_set failed, error 255
[ 143.496302] dwm spi0.0: reseting bridge
[ 143.522849] dwm spi0.0: dwm_reset failed, error -14
[ 143.522856] dwm spi0.0: bridge can’t be initialized, error -14
[ 146.912742] dwm spi0.0: invalid bridge config detected = 0x2812
[ 146.912755] dwm spi0.0: configuring bridge …
[ 147.016131] dwm spi0.0: reseting bridge
[ 147.044550] dwm spi0.0: decode TLV failed, error -1 t:255 l:255
[ 147.044560] dwm spi0.0: dwm_reset failed, error 0
[ 147.044564] dwm spi0.0: bridge can’t be initialized, error -14
[ 150.432827] dwm spi0.0: invalid bridge config detected = 0x2812
[ 150.432839] dwm spi0.0: configuring bridge …
[ 150.536235] dwm spi0.0: reseting bridge
[ 151.591816] dwm spi0.0: bridge ok
[ 182.232434] dwm spi0.0: bridge not responding
[ 182.232470] dwm spi0.0: reinitialize …
[ 185.633560] dwm spi0.0: invalid bridge config detected = 0x2812
[ 185.633574] dwm spi0.0: configuring bridge …
[ 185.736972] dwm spi0.0: reseting bridge
[ 186.792523] dwm spi0.0: bridge ok
[ 217.432831] dwm spi0.0: bridge not responding
[ 217.432865] dwm spi0.0: reinitialize …
[ 220.833933] dwm spi0.0: invalid bridge config detected = 0x2812
[ 220.833947] dwm spi0.0: configuring bridge …
[ 220.937342] dwm spi0.0: reseting bridge
[ 221.992897] dwm spi0.0: bridge ok
[ 252.633086] dwm spi0.0: bridge not responding
[ 252.633120] dwm spi0.0: reinitialize …
[ 256.034188] dwm spi0.0: invalid bridge config detected = 0x2812
[ 256.034202] dwm spi0.0: configuring bridge …
[ 256.137593] dwm spi0.0: reseting bridge
[ 257.193143] dwm spi0.0: bridge ok
[ 287.834148] dwm spi0.0: bridge not responding
[ 287.834180] dwm spi0.0: reinitialize …
[ 291.235329] dwm spi0.0: invalid bridge config detected = 0x2812
[ 291.235342] dwm spi0.0: configuring bridge …
[ 291.338740] dwm spi0.0: reseting bridge
[ 292.394314] dwm spi0.0: bridge ok
[ 323.035088] dwm spi0.0: bridge not responding
[ 323.035121] dwm spi0.0: reinitialize …
[ 326.436273] dwm spi0.0: invalid bridge config detected = 0x2812
[ 326.436286] dwm spi0.0: configuring bridge …
[ 326.539673] dwm spi0.0: reseting bridge
[ 327.595206] dwm spi0.0: bridge ok
[ 358.235764] dwm spi0.0: bridge not responding
[ 358.235797] dwm spi0.0: reinitialize …
[ 361.636897] dwm spi0.0: invalid bridge config detected = 0x2812
[ 361.636909] dwm spi0.0: configuring bridge …
[ 361.740310] dwm spi0.0: reseting bridge
[ 362.795869] dwm spi0.0: bridge ok
thank you!
