Gateway redundancy
@abd you need to select one gateway as the primary one for the DWM Proxy. Then configure all the others DWM Daemon to connect to that Proxy. The Proxy will handle filtering of duplicated data and data routing for the downlink. DWM Daemon can be configured in /etc/dwm1001/dwm1001.config
You can find more details also in this post:
@securigy2 I guess you have misinterpreted some information. The gateway collects the location and quality information from the Tags, so it cannot be different on each gateway.
