Dear Qorvo UWB Support Team,
We are evaluating the Qorvo UWB SDK v1.1.1 on the DWM3001CDK (Nordic nRF52833 + DW3000) for a 6-node body-tracking research prototype running FreeRTOS and Nordic SoftDevice S113 v7.2.0.
Application Configuration:
- Role: FiRa Star Ranging Coordinator (Pelvis) with 5 Controlee Responders
- Block Interval: 200 ms (5.0 Hz)
- Proprietary Stack Archive: libuwbstack_bundle_fira_arm-cortex-m4-hard_floating_rtos_R12.7.0-00405-gb33c5c42726c.a
- PHY Configuration: Channel 9 (Center frequency: 7987.2 MHz), PRF 64 MHz, Preamble Length 64 symbols + 8 SFD symbols
Observed Issue:
During extended operational testing (8,871 recorded ranging blocks over 30 minutes), our application supervisor recorded two coordinator hangs. In both instances, in-flight driver telemetry recorded the following sequence:
- In ull_starttx(), delayed transmission was initiated, but byte 3 of SYS_STATUS returned 0x08 (HPDWARN = 1).
- The measured residual time between DX_TIME and SYS_TIME[39:8] was +9,618 ticks (approx 38.5 µs) in the first incident, and +10,208 ticks (approx 40.9 µs) in the second incident.
- In accordance with driver recovery recommendations, the driver executed CMD_TXRXOFF, cleared HPDWARN, and returned DWT_ERROR (-1).
- The LLHW MCPS ops layer (llhw_mcps_ops.c) translated DWT_ERROR to QERR_ETIME (-24) and returned it to mcps802154_fproc_tx_handle().
- Following this return, coordinator ranging callbacks ceased completely. FreeRTOS task status indicated the coordinator application task in eReady, but no further ranging operations were scheduled, requiring a software supervisor reset.
Technical Questions:
- What minimum preparation lead time (in DTU or microseconds) is required by the DW3000 internal sequencer prior to transmission for Channel 9 with a 64-symbol preamble + 8-symbol SFD configuration? Is a residual time of 38.5–40.9 µs expected to trip HPDWARN?
- Is the LLHW anticipation margin (currently ANTICIP_DTU_100US = 20 / 2.0 ms in header files) consumed by precompiled logic inside libuwbstack_bundle_fira…a, and is there a supported API mechanism to increase this lead time (e.g. to 4.0 ms) to accommodate RTOS scheduling jitter?
- What is the intended recovery contract for the proprietary FiRa/MCPS scheduler when an LLHW tx_frame callback returns QERR_ETIME on a coordinator Poll frame? Should the scheduler drop the active slot and advance to the next scheduled round, or does this condition require external session re-initialization?
- Is an updated release or documented erratum available for libuwbstack_bundle_fira…a on Cortex-M4 that resolves ranging stalls following late delayed-TX aborts?
- What diagnostic telemetry or trace hooks would you recommend we capture from the precompiled stack to help identify the scheduler state following an aborted transmission?
