I was trying to build debug and run the “dwm” imported project from the DWM1001_on-board package.
I have started by mounting the DWM1001 Virtual Machine in the Oracle Virtual Box as described in the “DWM_Firmware_User_Guide.pdf”.
Then, I have imported the “dwm” project example to the eclipse environment as described in the section 4.2.2 of the firmware_User_Guide document.
The build was successful, however while trying to run the project, it showed a message on the console as follows:
(exit value 127) dwm-simple_fw2[c/c++Application] home/dw/workspace/dwm/examples/dwm-simple/dwm-simple_fw2
Is it an error message?
How can I handle that?
Thank you.
