Hello!
I’m trying to figure out if it is possible to add an external device to a PANS (for instance any UWB capable device) to work as a tag node. The idea is to use DWM1001 modules as Anchors and multiple devices as tags in order to have as much tags sources as possible.
Has anybody tried to do something alike? Any leads would be greatly appreciated
Hi @pvgonzalez ,
I have the same question and am also gathering information.
Could you find an answer or do a test?
I’ve been reading about it, as DWM1001 complies 802.15.4 at least the radio part should be compatible with any device. The thing is, it is my understandig that the ranging approach (at least the one in the examples) is closed so other devices should implement this particular method. I asked for clarification in another topic anyway.
@karina1357 We can discuss more in detail in you want
Sure!
I’d love to read your other topic on the subject as well. Can you send the link to it, please?
