I’m attempting to write my own command to initiate communication from one EVB1000 (which makes use of the DW1000 chip with an STM32 ARM microcontroller) to another EVB1000. I’m currently using a virtual COM port (Docklight) for the tag, while listening with the other device in DecaRanging. I am reading through the DecaRanging Source Code Guide to find the command byte format. Section 6.2 has some helpful information.
My goal is to send a command from COM Port terminal to Tag to initiate a Tag Blink, that is received (wirelessly) by the listening device and read on DecaRanging.
Has anyone successfully done this? I am new to firmware development and have limited experience.
Thank you.
