Hi @carlos.silva
I’m using the DWM3001CDK, and the SDK developer guide I found here (https://www.qorvo.com/products/d/da008604 page 29-30, section 6) indicates that the DWM3001CDK provides AoA values. However, I’m unable to get AoA data. Also with CLI build I’m getting “found a non AoA device” in the responder side, but the document (page 27) shows AoA device. Could you please clarify if I’m following the correct document and procedure? If not, can you suggest which board would support AoA functionality?
Thank You
Hi @Bhargavi ,
I propose for you QM33120 which supports AoA.
Sorry, but the capture in the document is taken from aoa device so they do not apply for DWM3001CDK.
https://www.qorvo.com/products/p/QM33120WDK1
