Hello, I am working on a school project that requires dwm 1001 and raspberry pi. I have research about the configuration of dwm1001 and raspberry pi. is the only way to configure both by a physical connection with a bridge and soldering? Because it is school property, I am skeptical about soldering it. Is there another way for this configuration?
You only need to solder a socket strip on the dwm1001. Then you plug it on the raspberry pi.
So the raspberry pi will not be damaged.
Kind regards
