DWM1001 VDDIO test point location
Looking at the figure 6 in DWM1001 datasheet and comparing it to the module itself, it seems that the testpoint location is not correctly drawn - in the land pattern it should be located more to the right. Am I correct?
The DS drawing is ambiguous. The way it is drawn is from the back side perspective. So the VDDIO Testpoint is correct in that context.
But one could argue that the land pattern should be from the front/plan view. We will clear this up in the next DS release.
OK, thank you. As you’ve mentioned, I’m used to land patterns from the front.
