Dear all,
The new DWM1001-API-Guide-2.1.pdf holds commands to set / get panid to set or get the network identifier of the node = a 2-byte integer. As this is already documented I’d like to know how I can get DWM1001 modules to answer those calls via UART. It seams they are currently not supported, a DWM1001 module always answers with the result of standard dwm_cfg_get call (when sending dwm_panid_get).
Any idea to get this to work? Will my DWM1001 modules need an update to support these functions?
Thanks!
