The question is:
On datasheet the CIR register is 4064 bytes " 0x25 4064 RO ACC_MEM Read access to accumulator data "
and on the log file as you can see it giving me only 41/61 bytes (20 bytes per connected anchor) and there are no changes in the data even if I am moving the anchors.
am I missing something?
Is this data really the CIR?
Any advice, please!!
Thank you, Yves!
Is there a firmware that I can start from doing my changes?
Some source C code?
I found C code in:
DWM1001_DWM1001-DEV_MDEK1001_Sources_and_Docs_v8\DWM1001\Source_Code\dwm1001_on-board_package_v1p0\dwm
Is it the right one?
You said there is no possibility to get register data with PANS software. What about PANS 2.0? It will also be impossible?
Hi [color=#333333][size=small]MLEV,[/size][/color]
[color=#333333][size=small]It is not possible for PANS and any derived version.[/size][/color]
[color=#333333][size=small]The [/size][/color][color=#333333][size=small]dwm project is a user application project within PANS and you will not be able to read the accumulator from [/size][/color][color=#333333][size=small]t[/size][/color][color=#333333][size=small]here.[/size][/color]
[color=#333333][size=small][color=#333333][size=small]You need to develop a fully custom firmware but you will lose all the location stack implemented with PANS (concept of “anchors”, "tags).[/size][/color][/size][/color]
[color=#333333][size=small][color=#333333][size=small]See the examples below for a C project implementing TWR on the dwm1001:[/size][/color][/size][/color]
Hi Yves,
I understand that I need to develop new firmware, but my question is about existing firmware.
Can I get it somewhere (I mean source code) or it’s business secret of DW?
And where can I find the guide for changing the firmware?
[color=#333333][color=#333333][size=small]But it is not a full RTLS stack so depending on what your final [/size][size=x-small]application[/size][size=small] is it may no suit.[/size][/color][/color]
