DW1000 Power Spectrum Caliberation
How to set the transmit power to meet the limit of -41.3dBm/Hz?
Regards
Riyaz
Hi Riyaz,
If you are using DWM1001C then you’re facing the same situation as I do.
As of now turns out that you must set the txconfig using the values stored on the OTP memory (these values are only set if you use the “C” version of the module). More info can be found on the modules manual.
I also ask you what kind of instrument are you using to measure the spectral power and what bandwidth?
