Is it possible to disable Reed Solomon on transmission and/or reception?
Not sure what you are trying to do here, can you elaborate?
The Tx will use RS encoding, this cannot be disabled. The DIS_RSDE bit can be used in the Rx side to ignore RS errors and continue frame reception, which ultimately will be corrupt.
I’m trying to come up with my own encoding/decoding scheme. So, I need to disable CRC check (FCE), RS error (RSDE), and any PHY errors (PHE).
I’m aware of DIS_FCE, DIS_PHE, and DIS_RSDE bits and also the possibility to disable adding CRC on the packet, but I’m not sure what behavior I should expect on the receiver side when these errors occur.
See my other question: Reception behavior when enabling DIS_FCE, DIS_PHE, and DIS_RSDE
Can I still read the corrupt data from the memory? and how?
