I am attempting to follow the DWM1001 Gateway Quick Deployment Guide in an attempt to ultimately get the DWM1001 connected to the Raspberry Pi. One of the first steps is setting up an UART connection between the DWM1001 and the PC. To do this they recommend using tera term. Unfortunately when I plug in the module to the PC nothing shows up and there are no ports to chose from. Is there some driver i should have installed first?
Hello Gregory
The SEGGER Jlink CDC driver needs to be installed. This should be automatically installed by Windows, but on other platforms or older Windows versions you can install the J-link software package. There used to be a way to just install just the CDC driver but it seems to have been removed.
