If i has several clusters of 16 anchors,
The system capacity is 150Hz to each cluster or to all of system?
Best Regards
Best Regards
Hi Costa,
It depends on how delimited are you clusters. The tag slots can be reused if there is enough separation between clusters. Similarly anchors seat can be reused.
The system capacity is always 150Hz but as two tags can potentially use the same slot , it means you can effectively track more tags than the bandwidth allows.
Hi Yves_Bernard,
ok, tags can use the same slot, when exist distance enough between anchors clusters, i.e. when not exist clock level difference between clusters.
Thank for your reply.
Bes regards
