hi, all:
we see that CH5 get the PDOA, how to get the CH2’s angle ?
hi, all:
Same principle applies, the CH2 Node antenna array will be ‘wider’ to satisfy < lambda/2 requirement.
default AOA board, I change the ch5 to ch2, but don’t get the right angle, so the antenna don’t support the CH2?
The PDoA antenna hardware is designed for CH5 only.
You will need a new Antenna for CH2. We do not have a CH2 design avaialble.
hi, Kenneth:
Thanks, If we use CH2, will the effect be better ? Because the penetration of the low frequency is stronger
CH2 will get you better range.
We have found that CH5 works very well for access use cases for example.
