C++ automatic port update
Hi everyone,
I am using C++ blocks in my simulation. Whenever I add or remove a port on the block, the code does not update accordingly. What am I doing wrong?
Regards,
Samo
Yes, I also delete manually on the c code.
Hi, samosmodis.
Adding/removing ports does not automatically change the C++ code. You’ll need to regenerate the C-Block and copy/paste the uData changes into your existing code.
I’ve posted a QSpice code generator that takes some of the annoyance out of the process. If you’re interested, see the QCodeGen project on the dev branch of my GitHub repo here.
–robert
