Hello ,
I am facing issue to use acas command get message is failed below is the details
Use Teraterm terminal with Baud Rate 115200
then set to frst
then use command nmi It works
then nis it also work
Set the encryption key using aks it also work
But acas is not working so not able to make enc on
