About Derivative Command in QSPICE
If you are certain that the event must occur between 1.8m and 1.9m, for example, you simply need to run the simulation .tran 0 1.9m 1.8m. This will save simulation data only between 1.8m and 1.9m seconds, and your .meas will only return results within this duration.
